Ir para o conteúdo principal
ASUS G73JH-BST7 SD Hard Drive Replacement
O que você precisa
  1. ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: passo 1, imagem 1 %32 ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Flip the computer over, so that the bottom is facing up.
  2. ASUS G73JH-BST7 SD Hard Drive Replacement: passo 2, imagem 1 %32 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 2, imagem 2 %32 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 2, imagem 3 %32
    • Slide the two tabs away from the battery.
    • The left tab will lock, but the right tab must be held away from the battery.
  3. ASUS G73JH-BST7 SD Hard Drive Replacement: passo 3, imagem 1 %32 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 3, imagem 2 %32 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 3, imagem 3 %32
    • Use one hand to hold the non-locking tab in place, and use your other hand to pull the battery away from the computer.
  4. ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: passo 4, imagem 1 %32 ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: passo 4, imagem 2 %32 ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: passo 4, imagem 3 %32
    • With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
  5. ASUS G73JH-BST7 SD Hard Drive Replacement: passo 5, imagem 1 %32 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 5, imagem 2 %32 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 5, imagem 3 %32
    • Carefully pry the panel away from the computer, by lifting with a finger.
    • There is a small tab where a finger will fit to lift the panel away from the computer.
  6. ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: passo 6, imagem 1 %32 ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: passo 6, imagem 2 %32 ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: passo 6, imagem 3 %32
    • Gently pull on the tabs to lift the SD Hard Drives out of the computer.
Conclusão
Deven Rodgers
Membro desde: 10/23/18
253 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 396
