Ir para o conteúdo principal
ASUS EEE PC701SD-WHI004X Keyboard Replacement
O que você precisa
  1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: passo 1, imagem 1 %32 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over, you should see two battery tabs.
    • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
    Pergunte ao FixBot
    Comentar
  2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: passo 2, imagem 1 %32 ASUS EEE PC701SD-WHI004X Keyboard Replacement: passo 2, imagem 2 %32
    • While holding the left tab towards the left. Gently slide the battery out of the laptop.
    Pergunte ao FixBot
    Comentar
  3. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
    • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
    • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
    Pergunte ao FixBot
    Comentar
  4. ASUS EEE PC701SD-WHI004X Keyboard Replacement: passo 4, imagem 1 %32 ASUS EEE PC701SD-WHI004X Keyboard Replacement: passo 4, imagem 2 %32 ASUS EEE PC701SD-WHI004X Keyboard Replacement: passo 4, imagem 3 %32
    • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
    • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
    • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
mir
Membro desde: 03/24/17
409 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 32
Ao todo: 926
