Ir para o conteúdo principal
ASUS Chromebook C300MA-DH01 Battery Replacement
O que você precisa
  1. ASUS Chromebook C300MA-DH01 Battery  Replacement, Battery: passo 1, imagem 1 %32
    • Flip the Chromebook over so the bottom of the device is facing up.
    Pergunte ao FixBot
    Comentar
  2. ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 2, imagem 1 %32 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 2, imagem 2 %32
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom
    • (5) Five 6mm screws
    • (6) Six 8mm screws
    Pergunte ao FixBot
    Comentar
  3. ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 3, imagem 1 %32 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 3, imagem 2 %32 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 3, imagem 3 %32
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
    Pergunte ao FixBot
    Comentar
  4. ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 4, imagem 1 %32 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 4, imagem 2 %32 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 4, imagem 3 %32
    • Gently detach connecting cables:
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
    Pergunte ao FixBot
    Comentar
  5. ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 5, imagem 1 %32 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 5, imagem 2 %32
    • Using the JIS-J0 Screwdriver, remove the (6) six 6 mm screws from the battery.
    Pergunte ao FixBot
    Comentar
  6. ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 6, imagem 1 %32
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
amer khalil
Membro desde: 09/26/17
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S2-G5, Passmore Fall 2017 Membro de USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 450
