Introdução
This guide will take you through a step-by-step process for the removal of your Chromebook’s screen.
O que você precisa
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Disconnect the screen cable connector located on the top right of the motherboard.
Using a spudger, gently pry up the sides of the connector.
Pull the connector off with your fingers.
Grab the sides of the Chromebook as if you were opening it.
Slowly hinge the back of the Chromebook away from the screen.
Use your middle fingers to push the back of the Chromebook towards you, and away from the hinges. At this point the keyboard and the screen should be completely seperated
