Ir para o conteúdo principal
ASDA ES177 Steam Iron Power cord Replacement
O que você precisa
  1. ASDA ES177 Steam Iron Power cord Replacement, Disassembly: passo 1, imagem 1 %32 ASDA ES177 Steam Iron Power cord Replacement, Disassembly: passo 1, imagem 2 %32 ASDA ES177 Steam Iron Power cord Replacement, Disassembly: passo 1, imagem 3 %32
    • Remove the security screw from the back panel.
    • Be cautious of any residual charge when disassembling.
  2. ASDA ES177 Steam Iron Power cord Replacement, Remove the back plate: passo 2, imagem 1 %32 ASDA ES177 Steam Iron Power cord Replacement, Remove the back plate: passo 2, imagem 2 %32 ASDA ES177 Steam Iron Power cord Replacement, Remove the back plate: passo 2, imagem 3 %32
    • Insert a flathead screwdriver to pop off the back plate
  3. ASDA ES177 Steam Iron Power cord Replacement, Remove the cord from the holder: passo 3, imagem 1 %32 ASDA ES177 Steam Iron Power cord Replacement, Remove the cord from the holder: passo 3, imagem 2 %32 ASDA ES177 Steam Iron Power cord Replacement, Remove the cord from the holder: passo 3, imagem 3 %32
    • Remove the retainer clamp by unscrewing the two Phillips screws.
  4. ASDA ES177 Steam Iron Power cord Replacement, Release the cord from the connector: passo 4, imagem 1 %32 ASDA ES177 Steam Iron Power cord Replacement, Release the cord from the connector: passo 4, imagem 2 %32 ASDA ES177 Steam Iron Power cord Replacement, Release the cord from the connector: passo 4, imagem 3 %32
    • Remove the three flat-headed screws from the connector
  5. ASDA ES177 Steam Iron Power cord Replacement, Remove the plug: passo 5, imagem 1 %32 ASDA ES177 Steam Iron Power cord Replacement, Remove the plug: passo 5, imagem 2 %32 ASDA ES177 Steam Iron Power cord Replacement, Remove the plug: passo 5, imagem 3 %32
    • Unscrew the main screw to reveal the 3-core cable.
    • Remove the two screws that retain the cord in the plug.
  6. ASDA ES177 Steam Iron Power cord Replacement, Remove the rotator support: passo 6, imagem 1 %32
    • Remove the rotator guide.
Conclusão
honakrisi
Membro desde: 01/28/20
3.730 Reputação
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 983
