Ir para o conteúdo principal
APS Tech 101629 Exhaust Fan Replacement
O que você precisa
    1. APS Tech 101629 Exhaust Fan Replacement, External Casing: passo 1, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement, External Casing: passo 1, imagem 2 %32 APS Tech 101629 Exhaust Fan Replacement, External Casing: passo 1, imagem 3 %32
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      Pergunte ao FixBot
      Comentar
    2. APS Tech 101629 Exhaust Fan Replacement: passo 2, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 2, imagem 2 %32
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. APS Tech 101629 Exhaust Fan Replacement: passo 3, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 3, imagem 2 %32
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      Pergunte ao FixBot
      Comentar
    4. APS Tech 101629 Exhaust Fan Replacement: passo 4, imagem 1 %32
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      Pergunte ao FixBot
      Comentar
    5. APS Tech 101629 Exhaust Fan Replacement: passo 5, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 5, imagem 2 %32
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      Pergunte ao FixBot
      Comentar
    1. APS Tech 101629 Exhaust Fan Replacement, Channel Switch: passo 6, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement, Channel Switch: passo 6, imagem 2 %32
      • Find the conjoined ID cable wires that are colored black, orange, and yellow.
      • Lift white portion of cable wires to disconnect it.
      Pergunte ao FixBot
      Comentar
    2. APS Tech 101629 Exhaust Fan Replacement: passo 7, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 7, imagem 2 %32 APS Tech 101629 Exhaust Fan Replacement: passo 7, imagem 3 %32
      • At this point, the fan is loose and can be easily moved but not disconnected.
      • Using the spudger, depress the pressure holders at all four corners of the fan.
      • Take out the fan and its cords, by pulling it outward from its cavity within the device.
      Pergunte ao FixBot
      Comentar
    1. APS Tech 101629 Exhaust Fan Replacement, Power Switch: passo 8, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement, Power Switch: passo 8, imagem 2 %32
      • Depress 2 pressure holds on each side of the power switch.
      • Press out the back of the device.
      Pergunte ao FixBot
      Comentar
    2. APS Tech 101629 Exhaust Fan Replacement: passo 9, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 9, imagem 2 %32
      • Remove all four 4 connections from the power switch.
      • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
      • These are very hard to get off, use patience and wiggling.
      Pergunte ao FixBot
      Comentar
    1. APS Tech 101629 Exhaust Fan Replacement, Exhaust Fan: passo 10, imagem 1 %32
      • Remove temperature guage.
      Pergunte ao FixBot
      Comentar
    2. APS Tech 101629 Exhaust Fan Replacement: passo 11, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 11, imagem 2 %32 APS Tech 101629 Exhaust Fan Replacement: passo 11, imagem 3 %32
      • Move the exhaust fan out of the way so you can access its control cord.
      • Use the spudger to depress the hold on the fan cord.
      • Gently pull fan cord from connection and remove fan completely.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 24-60, Amido Spring 2011 Membro de Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 1,121
