Ir para o conteúdo principal
APEX TM785CH Microphone Replacement
O que você precisa
  1. APEX TM785CH Microphone Replacement, Back Casing: passo 1, imagem 1 %32 APEX TM785CH Microphone Replacement, Back Casing: passo 1, imagem 2 %32
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Microphone Replacement, Microphone: passo 2, imagem 1 %32 APEX TM785CH Microphone Replacement, Microphone: passo 2, imagem 2 %32 APEX TM785CH Microphone Replacement, Microphone: passo 2, imagem 3 %32
    • The microphone is located in the bottom center of the tablet.
    • Remove the black tape holding the wires down.
    • Remove the black tape holding the microphone in place.
    • The microphone is now exposed and can be gently pulled out of the socket.
  3. APEX TM785CH Microphone Replacement: passo 3, imagem 1 %32
    • You will need a soldering/desoldering kit to desolder the 2 leads where the microphone connects to the circuit board.
Conclusão
Brian Graschel
Membro desde: 03/23/15
823 Reputação
Autoria de 6 guias
Equipe
Baylor, Team 4-1, Williams Spring 2015 Membro de Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 176
