Ir para o conteúdo principal
AEE Mach 1 Motherboard Replacement
O que você precisa
  1. AEE Mach 1 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Take out the AEE Mach 1 and place it on a flat surface with its propellers facing up.
  2. AEE Mach 1 Motherboard Replacement: passo 2, imagem 1 %32 AEE Mach 1 Motherboard Replacement: passo 2, imagem 2 %32
    • Holding the base of each propeller still, unscrew the propeller clockwise for each arm.
  3. AEE Mach 1 Motherboard Replacement: passo 3, imagem 1 %32
    • Flip the drone so that the bottom of the AEE Mach 1 is facing up.
  4. AEE Mach 1 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the five screws on the drone's arms using a Torx T5 screwdriver.
  5. AEE Mach 1 Motherboard Replacement: passo 5, imagem 1 %32
    • Gently pry open the top panel of the drone using a spudger.
    • Do not completely remove the panel, as there will still be wired connections between the two halves.
  6. AEE Mach 1 Motherboard Replacement: passo 6, imagem 1 %32
    • Take out and set aside the battery pack, located on the back of the AEE Mach 1.
  7. AEE Mach 1 Motherboard Replacement: passo 7, imagem 1 %32
    • Rotate the top panel slightly to reveal the four screws beneath each propellor arm.
    • Remove each of the four screws with a Phillips #0 screwdriver.
    • Lift off the top panel, as it should now be free from the rest of the device.
  8. AEE Mach 1 Motherboard Replacement: passo 8, imagem 1 %32 AEE Mach 1 Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the four screws from each corner of the motherboard with a Phillips #00 screwdriver.
  9. AEE Mach 1 Motherboard Replacement: passo 9, imagem 1 %32 AEE Mach 1 Motherboard Replacement: passo 9, imagem 2 %32
    • Use a plastic spudger to gently remove the copper tape from the mother board.
  10. AEE Mach 1 Motherboard Replacement: passo 10, imagem 1 %32
    • Peeling up the copper tape will expose another metal chip that has wires that are soldered to the mother board.
    • Remove the four screws holding the secondary board in place using a Phillips #00 screwdriver.
  11. AEE Mach 1 Motherboard Replacement: passo 11, imagem 1 %32 AEE Mach 1 Motherboard Replacement: passo 11, imagem 2 %32 AEE Mach 1 Motherboard Replacement: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the ZIF connector joining the motherboard and secondary board by prying up the locking black tab and pulling out the cable with some blunt nosed tweezers.
    • Desolder the red and black wires joining the two boards.
    • For help soldering, check out our Como soldar e dessoldar contatos guide.
  12. AEE Mach 1 Motherboard Replacement: passo 12, imagem 1 %32
    • Remove the motherboard by lifting it from the case.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Ao todo: 333
