Ir para o conteúdo principal
AEE Mach 1 Battery Replacement
  1. AEE Mach 1 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that your device is powered off before doing any work.
    • The battery is located at the back of the drone, on the opposite end of the drone from the camera.
    • There are two tabs on the edge of each side of the battery.
    Pergunte ao FixBot
    Comentar
  2. AEE Mach 1 Battery Replacement: passo 2, imagem 1 %32
    • To remove the battery, simply grip the battery by the tabs, press down on both tabs, and pull the battery out.
    Pergunte ao FixBot
    Comentar
  3. AEE Mach 1 Battery Replacement: passo 3, imagem 1 %32
    • To replace the battery, simply slide it back into its place until the tabs click back into place. If you are having trouble doing this, you may be putting it in upside down. Try flipping it over and trying again.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
3Comentários do guia
purchase the aee mach 1 but it has no battery
Ulysses aka UL Salett - Responder Compartilhar
How do I get a new battery where do I look
haroldlknight55 - Responder Compartilhar
Hi, how do a o get a battery?
Nivaldo Santos - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 1,604
