Ir para o conteúdo principal
8BitDo SN30 Pro+ Controller Triggers Replacement
O que você precisa
  1. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: passo 1, imagem 1 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: passo 1, imagem 2 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: passo 1, imagem 3 %32
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
    Pergunte ao FixBot
    Comentar
  2. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: passo 2, imagem 1 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: passo 2, imagem 2 %32
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
    Pergunte ao FixBot
    Comentar
  3. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: passo 3, imagem 1 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
    Pergunte ao FixBot
    Comentar
  4. 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: passo 4, imagem 1 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: passo 4, imagem 2 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: passo 4, imagem 3 %32
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
    Pergunte ao FixBot
    Comentar
  5. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Covers: passo 5, imagem 1 %32
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
    Pergunte ao FixBot
    Comentar
  6. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: passo 6, imagem 1 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: passo 6, imagem 2 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: passo 6, imagem 3 %32
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
    Pergunte ao FixBot
    Comentar
  7. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: passo 7, imagem 1 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: passo 7, imagem 2 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: passo 7, imagem 3 %32
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
    Pergunte ao FixBot
    Comentar
  8. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: passo 8, imagem 1 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: passo 8, imagem 2 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: passo 8, imagem 3 %32
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
    Pergunte ao FixBot
    Comentar
  9. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: passo 9, imagem 1 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: passo 9, imagem 2 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: passo 9, imagem 3 %32
    • Release the three clips holding the trigger assembly to the main board.
    • Repeat with the other side.
    Pergunte ao FixBot
    Comentar
  10. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: passo 10, imagem 1 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: passo 10, imagem 2 %32 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: passo 10, imagem 3 %32
    • Bend the plastic tab over the locking hook. It helps to push the trigger back slightly, with your other hand.
    • Gently pry the each side of the trigger out of the round clips.
    • Both conductive pads are now accessible.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Brian W
Membro desde: 12/21/11
1.800 Reputação
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 31
Últimos 30 dias: 99
Ao todo: 4,802
