Ir para o conteúdo principal
8BitDo NES30 Pro Gamepad Button Replacement
O que você precisa
  1. 8BitDo NES30 Pro Gamepad Button Replacement, Button: passo 1, imagem 1 %32 8BitDo NES30 Pro Gamepad Button Replacement, Button: passo 1, imagem 2 %32
    • Hold the controller with its back facing towards you.
    • Insert an opening pick between the L1 or R1 button and the backplate, and pry the backplate off of the controller.
    Pergunte ao FixBot
    Comentar
  2. 8BitDo NES30 Pro Gamepad Button Replacement: passo 2, imagem 1 %32 8BitDo NES30 Pro Gamepad Button Replacement: passo 2, imagem 2 %32
    • Place the controller face down on a solid surface.
    • Remove the seven screws with the Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. 8BitDo NES30 Pro Gamepad Button Replacement: passo 3, imagem 1 %32
    • Lift the body of the controller up and away from the controller's face and buttons.
    Pergunte ao FixBot
    Comentar
  4. 8BitDo NES30 Pro Gamepad Button Replacement: passo 4, imagem 1 %32 8BitDo NES30 Pro Gamepad Button Replacement: passo 4, imagem 2 %32
    • Lift away the black rubber pads that sit between the face buttons and body of the controller.
    Pergunte ao FixBot
    Comentar
  5. 8BitDo NES30 Pro Gamepad Button Replacement: passo 5, imagem 1 %32
    • Lift the buttons out of the face of the controller.
    Pergunte ao FixBot
    Comentar
  6. 8BitDo NES30 Pro Gamepad Button Replacement: passo 6, imagem 1 %32 8BitDo NES30 Pro Gamepad Button Replacement: passo 6, imagem 2 %32
    • Align the notches of the face buttons to put them back into place.
    • Each button has a unique notch pattern so it can't be replaced incorrectly.
    • Attach the rubber pads by placing their smaller and larger holes around the matching size pegs.
    Pergunte ao FixBot
    Comentar
Conclusão
4Comentários do guia
Hello there, any idea where I can find those black rubber pads for replacement ? mine is torn.
Thx
Ben Kakita - Responder Compartilhar
sorry, i try to search every where, have a tone for other controller, even have for 8bitdo snes, but not for nes 30 pro.
if you find it, answer on that chat. Good luck
Freeman loran - Responder Compartilhar
I wrote 8BitDo support, and explained the issue. They sent me some pads for the price of postage, but only for the buttons -- they didn't send any for the d-pad, which I feel is probably an error on their part.
Izaak Xavier - Responder Compartilhar
The screws in the N30 Pro are #6 Torx now
Matt Baker - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 55
Ao todo: 3,193
