Ir para o conteúdo principal
5 Tips & Tricks
Vídeo de Apresentação
  1. 5 Tips & Tricks, SECRET CODES: passo 1, imagem 1 %32 5 Tips & Tricks, SECRET CODES: passo 1, imagem 2 %32 5 Tips & Tricks, SECRET CODES: passo 1, imagem 3 %32
    • Enter the code from the phone dialer app:
    • *#06# -IMEI number
    • *#1234# - firmware version
    • *#0228# - battery info
    Pergunte ao FixBot
    Comentar
  2. 5 Tips & Tricks, HIDDEN TEST MENU: passo 2, imagem 1 %32 5 Tips & Tricks, HIDDEN TEST MENU: passo 2, imagem 2 %32 5 Tips & Tricks, HIDDEN TEST MENU: passo 2, imagem 3 %32
    • Use this code *#0*# to enter the phone into the test menu.
    • From this menu you can run tests for vibration, RGB colors, touch-screen, vibration, loudspeaker output, camera, sensor check and so on.
    Pergunte ao FixBot
    Comentar
  3. 5 Tips & Tricks, SAFE MODE: passo 3, imagem 1 %32 5 Tips & Tricks, SAFE MODE: passo 3, imagem 2 %32 5 Tips & Tricks, SAFE MODE: passo 3, imagem 3 %32
    • Switch off the phone.
    • Press and holdthe Volume Down and the Power buttons.
    • When you see the Galaxy logo, release only the Power button
    • Now all third-party apps (apps that are installed by you) are disabled.
    • To exit Safe mode just tap on the Safe mode notification or restart the device manually.
    Pergunte ao FixBot
    Comentar
  4. 5 Tips & Tricks, DEVELOPER OPTIONS: passo 4, imagem 1 %32 5 Tips & Tricks, DEVELOPER OPTIONS: passo 4, imagem 2 %32 5 Tips & Tricks, DEVELOPER OPTIONS: passo 4, imagem 3 %32
    • Go to >Menu >Settings >About device, Scroll down to Build number, and tap it seven times.
    • Do not change the options if you do not know what you're doing.
    Pergunte ao FixBot
    Comentar
  5. 5 Tips & Tricks, SNAPSHOT: passo 5, imagem 1 %32 5 Tips & Tricks, SNAPSHOT: passo 5, imagem 2 %32
    • Press the Power and Home buttons at the same time until a shutter sound is heard or you see a visual indicating a picture was taken.
    • That's all. Did you like this guide?
    Pergunte ao FixBot
    Comentar
Conclusão
46 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
197.270 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
333 Membros
Autoria de 1.521 guias
1Comentário do guia
How to put mobile internet speed can you have sample code?
Richad Paker - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 72
Ao todo: 20,778
