Ir para o conteúdo principal
3DR Solo Propeller Disassembly
    1. 3DR Solo Propeller Disassembly, Propeller: passo 1, imagem 1 %32
      • Grip the arm, which is located underneath the propeller, with one hand, and with your dominant hand grip the center of the propeller.
      Pergunte ao FixBot
      Comentar
    2. 3DR Solo Propeller Disassembly: passo 2, imagem 1 %32
      • Twist the propeller from the locked to unlocked position as indicated by the images of the lock.
      • You will need to twist in this direction for 2-3 full rotations before the propeller will detach.
      Pergunte ao FixBot
      Comentar
    3. 3DR Solo Propeller Disassembly: passo 3, imagem 1 %32
      • Lift the propeller off the motor.
      • To remove the silver-top propellers, repeat these steps, turning the propellers in the opposite direction of the black-top propellers.
      Pergunte ao FixBot
      Comentar
Conclusão
Lauren Hays
Membro desde: 09/11/17
222 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team S2-G3, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G3, Bruce Fall 2017
CSUF-BRUCE-F17S2G3
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 919
