Ir para o conteúdo principal
2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement
O que você precisa
  1. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 1 %32 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 2 %32 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 3 %32
    • Here is the FOB for my Jeep. It decided to finally quit. The functionality became less over the last couple of weeks and required frequent attempts to unlock the vehicle etc.
    • Remove the key by moving
    • locking hatch to the left side first.
    • The two halves where the FOB needs to be split are clearly visible
  2. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 2, imagem 1 %32 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 2, imagem 2 %32 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 2, imagem 3 %32
    • Using a plastic opening tool (or finger nail, guitar pick etc.) start at the front of the FOB to separate it
    • Moving the tool along the split line with slight sideways pressure
    • will separate the FOB easily.
  3. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 3, imagem 1 %32 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 3, imagem 2 %32 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 3, imagem 3 %32
    • Here is the cleanly opened FOB
    • Bottom half of the FOB contains the CR2032 coin battery
    • Remove the battery by pulling it out of the holder pushing it gently against the spring contacts.
    • Replace the battery following the polarity with the positive side to the body of the FOB
  4. 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 4, imagem 1 %32 2011-2014 Jeep Grand Cherokee Key Fob Battery Replacement: passo 4, imagem 2 %32
    • Insert wisdom here.
Conclusão
12 outras pessoas executaram este guia.
oldturkey03
Membro desde: 09/29/10
783.775 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 551 guias
Um comentário
Very easy! Thank you!
Cheryl Talley - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 85
Últimos 30 dias: 448
Duração total: 71,579
