Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Here is a view of the left tail light assembly
Open the rear hatch,( or trunk if it is a sedan). On the inside of the assembly are two retaining screws. Remove those
both screws are #6x3/4 inch
Here is a view of the assembly with the screws removed.
Insert some sort of prying tool between the tail light assembly and the body, just below the crease in the body and pry to the rear of the vehicle. a snap will be felt/heard as the plastic stud releases
Move the prying tool to above 1 1/2 inch above the bottom of the assembly. Insert it between the assembly and body and gently pry toward the rear of the vehicle. This should free the second stud.
Now just pull the assembly straight back.
Locate the burned out bulb. In this case it was the indicator light. Rotate the bulb sockets in a counterclockwise direction.
Pull the sockets straight out of the tail light assembly.
7 outras pessoas executaram este guia.
2 comentários
Awesome guide!
This was a great help thank you!!
