Ir para o conteúdo principal
2005 Honda Pilot Rear Strut Replacement
O que você precisa
  1. 2005 Honda Pilot Rear Strut Replacement, Rear Struts: passo 1, imagem 1 %32
    • Begin by placing a support beneath the trunk that takes all the weight of the trunk.
  2. 2005 Honda Pilot Rear Strut Replacement: passo 2, imagem 1 %32
    • Insert the flat head screwdriver under the clip, at the top of the strut, and lift the clip until it pops off completely.
  3. 2005 Honda Pilot Rear Strut Replacement: passo 3, imagem 1 %32
    • Now, insert the flat head screwdriver under the clip, at the bottom of the strut, and lift the clip until it pops off completely.
  4. 2005 Honda Pilot Rear Strut Replacement: passo 4, imagem 1 %32
    • Line up the ball and the socket pieces of your new strut.
  5. 2005 Honda Pilot Rear Strut Replacement: passo 5, imagem 1 %32
    • Use force to push the strut and connect the ball and socket joint.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 209
