Ir para o conteúdo principal
2002 VW Jetta Driver Side Power Window Module Replacement
O que você precisa
  1. 2002 VW Jetta Driver Side Power Window Module Replacement, Power Window Module: passo 1, imagem 1 %32 2002 VW Jetta Driver Side Power Window Module Replacement, Power Window Module: passo 1, imagem 2 %32
    • Use a trim tool (or, optionally, a flathead screwdriver) to gently pry the interior plastic piece from the door bezel handle.
    • Remove the small plastic cover.
    Pergunte ao FixBot
    Comentar
  2. 2002 VW Jetta Driver Side Power Window Module Replacement: passo 2, imagem 1 %32 2002 VW Jetta Driver Side Power Window Module Replacement: passo 2, imagem 2 %32 2002 VW Jetta Driver Side Power Window Module Replacement: passo 2, imagem 3 %32
    • Insert the trim tool into the bottom of the bezel. Find a spot in the middle of the bezel, and gently push upward until the trim tool has the leverage needed, then push the bezel upward from the door.
    • Repeat this process at several points along the bottom and sides of the bezel to release all of the clips.
    • Find points that leverage both the left and right sides of the bezel.
    • When you remove the bezel, be very gentle when pushing upward. The interior plastic of most vehicles can be very fragile. Pushing upward aggressively can cause visible damage to the exterior of the bezel, and you can also damage the clips needed for securing the bezel to the door.
    Pergunte ao FixBot
    Comentar
  3. 2002 VW Jetta Driver Side Power Window Module Replacement: passo 3, imagem 1 %32 2002 VW Jetta Driver Side Power Window Module Replacement: passo 3, imagem 2 %32
    • Remove the bezel from the door.
    • Push down on the locking tab with your thumb and pull gently to disconnect the bright orange connector plugged into the adapter of the power control module.
    Pergunte ao FixBot
    Comentar
  4. 2002 VW Jetta Driver Side Power Window Module Replacement: passo 4, imagem 1 %32 2002 VW Jetta Driver Side Power Window Module Replacement: passo 4, imagem 2 %32 2002 VW Jetta Driver Side Power Window Module Replacement: passo 4, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove the three 4x10 mm screws on the bottom of the bezel that hold the power window module in place.
    • It doesn't matter what order you unscrew the screws, but keep them for reassembly.
    • Remove the power window module from the bezel.
    Pergunte ao FixBot
    Comentar
  5. 2002 VW Jetta Driver Side Power Window Module Replacement: passo 5, imagem 1 %32 2002 VW Jetta Driver Side Power Window Module Replacement: passo 5, imagem 2 %32
    • Insert the new power window module into the bezel.
    • The screw holes on the power window module must align with the holes in the bezel.
    • Don't force the power module in. It will be a flush fit. Line up the holes, and before you begin reinstallation, position the bezel downward with the screw holes facing up to keep the module in place.
    Pergunte ao FixBot
    Comentar
  6. 2002 VW Jetta Driver Side Power Window Module Replacement: passo 6, imagem 1 %32 2002 VW Jetta Driver Side Power Window Module Replacement: passo 6, imagem 2 %32 2002 VW Jetta Driver Side Power Window Module Replacement: passo 6, imagem 3 %32
    • Use the Phillips #2 screwdriver to replace the three 4x10 mm screws in the bezel to secure the power window module.
    • To avoid damaging the plastic bezel, do not screw the screws in too tightly. Stop rotating when you feel the screw is secure. Tightening any further could lead to damage to the screw holes and/or the bezel itself.
    Pergunte ao FixBot
    Comentar
  7. 2002 VW Jetta Driver Side Power Window Module Replacement: passo 7, imagem 1 %32 2002 VW Jetta Driver Side Power Window Module Replacement: passo 7, imagem 2 %32
    • Reconnect the bright orange connector to the adapter on the bottom of the power window module.
    • Align the bottom edge of the bezel with the door slots and press it into place.
    • You should feel it click into place.
    • Avoid using excessive force. If it feels difficult to press down, the clips are likely misaligned with the door slots. Forcing the bezel could damage it.
    Pergunte ao FixBot
    Comentar
  8. 2002 VW Jetta Driver Side Power Window Module Replacement: passo 8, imagem 1 %32 2002 VW Jetta Driver Side Power Window Module Replacement: passo 8, imagem 2 %32
    • Before installing the final piece, turn on the car and test the new power window module, checking all buttons to ensure proper operation.
    • Insert the small plastic piece from the handle of the bezel.
    • Align the clips on the small plastic piece with the holes on the inside of the handle and gently press toward the inside of the car.
    Pergunte ao FixBot
    Comentar
Conclusão
After completing this guide, the user will have a working driver-side power window module. If installed correctly, there should be no extra plastic pieces from the vehicle, and the bezel should be firmly reinserted with no moving or rattling. To avoid hazardous e-waste, discard the old power window module by taking it to a local e-waste recycler or a sponsored e-waste recycler nearby.
Uma outra pessoa concluiu este guia.
Ryan Davis
Membro desde: 09/22/25
181 Reputação
Autoria de 1 guia
Equipe
CSU Sacramento, Team 1-10, Laflen Fall 2025 Membro de CSU Sacramento, Team 1-10, Laflen Fall 2025
CSUSAC-LAFLEN-F25S1G10
1 Membro
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 64
Ao todo: 497
