Introdução
This guide is designed to assist in the service and repair of the Dualit toaster, showing the correct disassembly of the Dualit toaster
4 x rubber feet
5 x metal screws
Remove the rubber feet and screws with a phillips head screw driver.
1 x Matte Aluminium Bottom Plate
After removing the Feet and Screws the Bottom plate simply lifts off.
1 x Stainless Steel main casing
6 x Phillips Head Metal Screws
Remove screws from main body of toaster and ply the metal casing off with your hands from either side.
1 x Casted Aluminium End Cap from the left hand side of the toaster
After removing the screws from part 4 this end cap will just pull off with a gentle tug.
1 x Lever mechanism
1 x Spring
1 x Washer
1 x Plastic lever handle
2 x Aluminium fastening plates
To remove the Lever mechanism you must first unscrew and remove the black plastic handle.
After this the two fastening plate will can be removed. The screws holding these in place have already been removed in the previous step.
The lever mechanism can now be removed from the toaster. This may take some manoeuvring for the mechanism to slide out.
3 x heating elements
2 x Brass dividers
2 x Copper wires
2 x Bolts
6 x Washers
4 x Nuts
To remove the heating elements unscrew the bolts with the PH screwdriver whilst holding the nuts with the pliers
Once unscrewed the wires and copper dividers are able to be removed. Then simple slide out the heating elements. The elements need to be replaced in the same slots they came from so label them.
7Comentários do guia
What size are the screws used to secure the outer casing?
On my model A2BR/87 they’re #2 Pozidriv screws.
You can tell the difference between Phillips and Pozidriv screws because the latter have very small lines etched between the four arms of the cross on the screw head. Phillips screws (and screwdriver) should work, but if you use them too many times on a Pozidriv screw then they'll eventually wreck them. On the other hand, you can't use a Pozidriv screwdriver at all on a Phillips screw so check to see which kind of screw you have.
FWIW, I had to get Pozidriv screwdrivers to work on my Saeco espresso machine.
If you just need to replace the Dualit 2 slice toaster, Lifter Assembly what is involved in doing that. Surely you don't have to remove all the sides etc. What would you recommend to replace this one element?
unscrew the black round knob on the lifter and unfasten screws
Is the Cast Aluminum Timer Casing one part that is available? My toaster is an American Dualit. The timer mechanism doesn't work. I would like to replace just this part. Can you help me remove it?
