Ir para o conteúdo principal
1999-2002 Suzuki SV650 Seat Replacement
O que você precisa
  1. 1999-2002 Suzuki SV650 Seat Replacement, Seat: passo 1, imagem 1 %32 1999-2002 Suzuki SV650 Seat Replacement, Seat: passo 1, imagem 2 %32
    • If you have frame covers below your seat, remove them by removing the 4 mm allen bolts holding them on. Use a 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • Once the frame covers are off, remove the 4 mm allen seat bolts on both sides of the seat. Use the 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • The bolt in the picture is not stock.
    • Lift the front of the seat, then pull it off the frame.
Conclusão
Uma outra pessoa concluiu este guia.
Phillip Takahashi
Membro desde: 08/22/11
86.704 Reputação
Autoria de 87 guias
Um comentário
seat bolts are actually 6mm Allen (side covers are 4mm Allen).
thineownself - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 54
Duração total: 7,883
