Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Use a flathead screwdriver to remove the cap from the windshield wiper.
8 outras pessoas executaram este guia.
5 comentários
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
does it need to be programmed mine needs replacement my gears are not shifting
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
