Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a #2 Phillips screwdriver to remove the four screws.
Use a flathead screwdriver to remove the cap from the windshield wiper.
Use a socket wrench to release the passenger-side windshield wiper locking nut.
Gently lift up the passenger-side windshield wiper.
Remove the driver-side windshield wiper in the same fashion.
Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
Use a #2 Phillips screwdriver to remove the front two screws.
Gently unplug and lift out the automatic transmission control unit.
8 outras pessoas executaram este guia.
5 comentários
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
does it need to be programmed mine needs replacement my gears are not shifting
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
