Ir para o conteúdo principal
1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement
O que você precisa
  1. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: passo 1, imagem 1 %32 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: passo 1, imagem 2 %32 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: passo 1, imagem 3 %32
    • Here is the Jeep GC. Removal of the headlamp is identical for both sides.
    • By opening the hood and looking straight down on the headlamp assembly, the 6mm hex head jack screw can be seen.
    • Use a 6mm socket and nut driver to remove the jack screw. 1/4 socket will not fit 9/32 does, but it is a bit sloppy
  2. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: passo 2, imagem 1 %32 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: passo 2, imagem 2 %32 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: passo 2, imagem 3 %32
    • Remove the long jack screw.
    • Grasp upper inboard and lower outboard corners of headlamp and forcefully pull headlamp outward.
    • Remove all bulb sockets from headlamp module. Separate headlamp from vehicle.
Conclusão
6 outras pessoas executaram este guia.
oldturkey03
Membro desde: 09/29/10
782.402 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 543 guias
4 comentários
It’s a 7mm socket
Don Marcos - Responder
Not on mine. Just rechecked and it is a 6mm on my Jeep
oldturkey03 -
Thankful for simple instructions without any extra info or words ?
robinrogersk9 - Responder
I’m removing it to replace fan cooling module. I heard I can cut through to get to it without disassembling the grill bumper etc
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 34
Duração total: 7,561
