Ir para o conteúdo principal
12-String Takamine G Series Guitar String Replacement
O que você precisa
  1. 12-String Takamine G Series Guitar String Replacement, Guitar String: passo 1, imagem 1 %32 12-String Takamine G Series Guitar String Replacement, Guitar String: passo 1, imagem 2 %32 12-String Takamine G Series Guitar String Replacement, Guitar String: passo 1, imagem 3 %32
    • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
    • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
    Pergunte ao FixBot
    Comentar
  2. 12-String Takamine G Series Guitar String Replacement: passo 2, imagem 1 %32 12-String Takamine G Series Guitar String Replacement: passo 2, imagem 2 %32
    • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
    Pergunte ao FixBot
    Comentar
  3. 12-String Takamine G Series Guitar String Replacement: passo 3, imagem 1 %32 12-String Takamine G Series Guitar String Replacement: passo 3, imagem 2 %32
    • Place the new string into the hole in the bridge where the pin was taken out.
    Pergunte ao FixBot
    Comentar
  4. 12-String Takamine G Series Guitar String Replacement: passo 4, imagem 1 %32 12-String Takamine G Series Guitar String Replacement: passo 4, imagem 2 %32 12-String Takamine G Series Guitar String Replacement: passo 4, imagem 3 %32
    • Place the pin back into the hole to secure the string.
    Pergunte ao FixBot
    Comentar
  5. 12-String Takamine G Series Guitar String Replacement: passo 5, imagem 1 %32
    • Grab the string and put it through the hole located on the tuning post of the guitar.
    Pergunte ao FixBot
    Comentar
  6. 12-String Takamine G Series Guitar String Replacement: passo 6, imagem 1 %32 12-String Takamine G Series Guitar String Replacement: passo 6, imagem 2 %32 12-String Takamine G Series Guitar String Replacement: passo 6, imagem 3 %32
    • Take the string and wrap it around and underneath itself.
    • Pull the string taught.
    • Twist the string over itself and than cut off the excess string.
    Pergunte ao FixBot
    Comentar
  7. 12-String Takamine G Series Guitar String Replacement: passo 7, imagem 1 %32 12-String Takamine G Series Guitar String Replacement: passo 7, imagem 2 %32
    • Turn the tuning peg counterclockwise to tighten the string.
    Pergunte ao FixBot
    Comentar
Conclusão
Rey Navarro
Membro desde: 09/27/23
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 49
Ao todo: 857
