Ir para o conteúdo principal
01 | XY Frame Assembly
O que você precisa
  1. 01 | XY Frame Assembly, 01 | XY Frame Assembly: passo 1, imagem 1 %32 01 | XY Frame Assembly, 01 | XY Frame Assembly: passo 1, imagem 2 %32 01 | XY Frame Assembly, 01 | XY Frame Assembly: passo 1, imagem 3 %32
    • M8 x 40 screw for each corner. Insert T Nuts before M8 screws and do not tighten them now. Just to keep the frame in shape.
    • Blind L metal brackets for Z axis assembly should be inserted before M8 screws as well.
    • There are M8 holes for Z axis assembly on the 320mm aluminium extrusions which should be at the back of the XY Frame. Larger hole should be faced to bottom.
    • Insert two T-nuts for every corner in order to fasten the L brackets on the next step.
    • Do not forget to insert T Nuts for Y motor holder in back and LCD mount in front.
    Pergunte ao FixBot
    Comentar
  2. 01 | XY Frame Assembly: passo 2, imagem 1 %32 01 | XY Frame Assembly: passo 2, imagem 2 %32 01 | XY Frame Assembly: passo 2, imagem 3 %32
    • One Metal L Brackets for each corner.
    • Two M6x12 socket cap screws for each metal L brackets.
    • Please align the extrusions on a flat surface like glass or marble and then tighten the M8 screws on the corners and the inside L brackets.
    • T-Nut insert for each bottom corner.
    • Printed Zaribo L brackets.
    • Misumi rubber foot for each corner.
    • M6x20 socket cap screw.
    • Misumi 3030 aluminium extrusion edge cover.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Murathan Araz
Membro desde: 08/01/13
780 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 41
Ao todo: 3,381
