Ir para o conteúdo principal
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
How do I affix screen?
I successfully replaced the screen on my iPod Nano 6th Gen. However, I am not sure how to affix the screen to the device. Is there a particular adhesive that works best?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
I've tried both methods on the nano 6G. super glue is a great bond but nearly impossible to open again. 3M double sided tape works best - strong bond, yet can still be opened in the future.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks..will give double sided tape a try.
por
Sadly the guide neglects to mention you will need new tape to fully repair the 6G, however, here's the URL for the 3M double sided tape you should use to affix the screen to the case -
[produto vinculado ausente ou desativado: IF145-283-2]
It's more then you will need to finish the repair, however, this tape has a number of uses and is a welcome addition to my parts box.
por
good question, i use Two sided tape.
works well for me but it is weaker then the adhesive that originally was on the screen.
Pontuação 0
1 comentário:
Thanks..I will take a look at that option. I am also considering superglue as an option.
por
Adicionar a sua resposta
chris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 3,303
