Ir para o conteúdo principal
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
Not functioning correctly after water damage
i accidently dropped my 3DS in water. the power was on while underwater. i immediatly took it out of the water and then it automatically turned off. when i dried it off and turned it back on the top screen was completly black. after about 2 hours i turned it back on and the top screen was back on but there are now many other problems such as: circle pad moving by itself forcing all movements to go to the left
notifications light is staying lit green
A and X button not always responding.
does anyone know what i should do?? PLEASSEE HEELLP!!!!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
As with all devices that have been submerged in water, the best thing you can do is disassemble the device and clean all of the contacts with a cotton swab and a high concentration alcohol (>90% concentration). You can access most of the internals pretty easily by removing the lower case.
Esta resposta foi útil?
Pontuação 0
1 comentário:
^ thanks now I can try to fix mine :3
por
Adicionar a sua resposta
jkdnjn njinckjwnj será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 3,689
