Ir para o conteúdo principal
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
How do you get the glass out of the frame?
Got it all apart from the instructions, fine. Now I've got a frame with broken screen and can't get it out to replace it with the new screen?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Our guide was written with the assumption that you would be replacing the entire front panel, not just the glass panel. The glass is probably held in place with a very strong adhesive.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
I ran a hairdryer over the edges of the frame (with the cracked screen) and it melted the adhesive. Then I was able to pop out the screen from the frame!
Pontuação 2
1 comentário:
I used to a heat pack to accomplish the same. Wasn't nearly as scary as I thought it would be.
por
how to replace a gass on a samsung infuse
Pontuação 0
Adicionar a sua resposta
Jim P será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 994
