Ir para o conteúdo principal
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Perguntas Visualizar todos
How do I install a new Airport card?
Hi all,
I have a Macbook Pro A1286 and I can't seem to find any directions on where to replace the module. A picture is all I would need to see where I need to replace it.
Thank you,
Jase
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Start by choosing your machine the guide will give you plenty of pictures as well as list of tools - the job is always easier when you use the proper tools.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 0
I followed the guide choosing MacBook pro mid 2009 and did not see a guide for replacing airport card
Pontuação 0
1 comentário:
Opps! The team forgot to make a guide for this exact model. Not to fear! The older model is the same.
Here's the guide you need to follow: MacBook Pro 15" Unibody Late 2008 and Early 2009 Airport Card Replacement. I'll warn you this is a big job! You may want to find a good used display assembly and just swap out the whole assembly.
por
Adicionar a sua resposta
jaseinny será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 3,971
