Ir para o conteúdo principal
iSight light is always on
The green "camera is on" iSight light to the right of the iSight is perpetually on! I know that the camera is not actually on (the cable is not even connected), but it is still unnerving. Any ideas?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
the fact that the camera is disconnected does not stop the rest of the circuitry to switch off / on. So is the camera actually on when you connect the cable?
por
Adicionar um comentário
1 resposta
Solução escolhida
You should try disconnecting the cable to the light (if possible) and reconnecting it to see if that helps
Esta resposta foi útil?
Pontuação 0
2 comentários:
Well, this didn't fix the problem, but it gave me the motivation to open the machine and disconnect the cables. The light is definitively off now! Thanks!
por
I can see you!
por
Adicionar a sua resposta
Ben Eisenman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 2,820
