Ir para o conteúdo principal
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Perguntas Visualizar todos
Device was dropped, rarely powers on
Was dropped on its left back corner, where the DC in is. I disassembled the whole laptop, and checked the DC in board. Seemed ok. When reassembling, I made sure all the connections to the logic board were solid.
However, it still has the same problem - it simply won't power on. I reseated the ram too, and tried individual sticks on each slot. Still no change. When it's plugged into power, and I press the battery level indicator, it'll flash full.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Hi, Try resetting the SMC. Link on how to do this provided. Good luck.
http://support.apple.com/kb/HT3964
Esta resposta foi útil?
Pontuação 2
1 comentário:
I forgot to mention that I tried the SMC reset. I just tried it again, and still nothing. And response to the other commenter, when I took everything apart, all the connectors looked like they were connected properly, and as I was reassembling, I double checked it all.
The computer turns on every once in a great while, but it's rare.
por
reseat flex connector from the keyboard and power button to the logic board maybe its not fully connected or intact....
Pontuação 0
Adicionar a sua resposta
Ben Hodges será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 432
