Ir para o conteúdo principal
Guias de reparo, manuais e ajuda para a resolução de problemas das ferramentas de solda iFixit. Obtenha tudo o que precisa para reparar você mesmo as suas ferramentas de solda iFixit.
Soldering Hub won't charge
I bought my soldering hub from Microcenter and I have only used it one time. I tried to use it again around a month ago and it wouldn't charge. I went through the troubleshooting and it wont even connect to the update the firmware. I sent a message to I fix it and they have yet to respond. I am not sure what to do at this point I am just really disappointed in their customer service. Does anyone have any suggestions for next steps?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Have you tried going back to MicroCenter to see what they say?
At least they can verify the charger is working using a USB-C power meter inline with the charger to see what that shows. They maybe able to exchange the unit as well.
I've pinged the iFixit folks for you from here. As you know we are just about to start Thanksgiving so it will be sometime next week before anyone will respond at the earliest.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Thaddeus Skrzynecki será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 32
Últimos 30 dias: 32
Ao todo: 32
