Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
Remove or leave Film on LCD + Digitizer?
Hello everyone,
I'm rather new with replacing LCD's, but I managed to do one yesterday. For some reason I noticed a back film on the LCD + Digitizer looking like this:
Click photo!
Do I have to remove this one or not?
Greetings,
Mittchel
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Yes you must remove it or the screen won't work. I experienced this with a new iPhone 6 screen where the apple logo just kept flashing and would not respond to a reset via iTunes. Such a simple oversight which cost me hours of unnecessary work!!
por
Adicionar um comentário
2 respostas
Solução escolhida
Yes, remove this protective plastic sheet right before you install the Front Screen. Often there is a tab to help remove it like in your photo. Some Screens don't have the tab on the plastic, but you still remove the plastic sheet.
Esta resposta foi útil?
Pontuação 4
8 comentários:
Thanks. I wasn't sure, because in most videos they don't remove it. By the way.. does NOT removing this film this problem: Help needed! Strange colors on screen
Or is that something else?
por
So i tried to do the same but when i pulled it instead of the film coming off it pulled the whole thing off.. Is there any way i can fix this? Email me at corygandy@hotmail.com if you can...
por
Please answer the query of Mittchel. Does not removing the back film cause any problems?
por
Before assembling, I hooked up my new screen to test it. The film was still on the back and it worked fine. Digitizer fine too. But remember the phone can get pretty hot in the sun so it is probably best to remove the film so it doesnt melt inside the phone. I believe the film is even put there so that debris doesnt stick to the metal foil berore it is installed. That way it can conduct heat away better. I'm just guessing about that though.
por
Oh BTW this was an iphone 4.
por
Exibir mais 3 comentários
i have this same issue, i didn’t remove the film on my iPhone X screen replacement, now suffer random black screen while using the device most commonly noticed it will happen when changing orientation on my iPhone (Literally not orientation lock)
Pontuação 0
Adicionar a sua resposta
Mittchel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 74
Duração total: 25,000
