tiny triangular metal washer and 1mm x 2mm x 3mm foam block
these two pieces seem to come from the speaker assembly area. triangular washer was found magnetized to speaker back and tiny foam block was loose. location not apparent.
Esta é uma boa pergunta?
4 comentários
I think the photo of the spacer is for verizon model. the part i am refering to is of the same shape but silver metal. At &t model. it seems it would fit at the left side of the speaker(from the back). but does it fit under the motherboard, between the board and the metal threaded boss in the frame or on top under the 1.9 mm screw? Thank you for your help. the foam block is a small piece of black foam that would be a bushing or insulator. thanks you for you help
por MarkMatsuda
MarkMatsuda,click on the orange tab "Images" on the bottom left of this page, a tab will open on the bottom of this screen, click on upload. Of course you will have to be in "edit" your question. Once uploaded the image will be in the bottom tab. Left click and hold and drag the image into the edit screen of your question. Now I've posted the images you linked to in your comment. Let us know if that is the right image. Good Luck.
por oldturkey03
thanks oldturkey03 for the quick picture upload tutorial =) unfortunately thats the picture i linked to in my comment and not the one MarkMatsuda is looking for. Do you mind if I remove the picture you posted?
por Walter Galan
Of course not :) whatever it takes to help out, is good by me :)
por oldturkey03
