Ir para o conteúdo principal
Xiaomi Redmi Note 13 4G Lançado em 15 de janeiro de 2024 188,5 g, 8 mm de espessura Android 13, até 15 Armazenamento de 128 GB/256 GB/512 GB, microSDXC
My Redmi Note 13 won't turn on.
Xiaomi Redmi Note 13 4G"> My Xiaomi Redmi Note 13 4G won't turn on. I have tried forced restarts (holding power and volume buttons), charging for over 30 minutes with the original charger, and trying to enter Recovery Mode, but the phone remains completely unresponsive with no screen activity, LED, or vibration. What hardware component or further troubleshooting should I check?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If it’s completely dead with no vibration, charging symbol, or LED, I’d start looking at the battery and charging/power circuit rather than software.
Try a different known-good USB-C cable/charger and check the port for damage or debris. If still completely dead, the next step is measuring the battery voltage and checking whether power is reaching the board.
At that point, a failed battery, charging port, fuse, or power-management IC are all possibilities.
Esta resposta foi útil?
Pontuação 0
1 comentário:
It didn't work, he still doesn't call.
por
Adicionar a sua resposta
Luiz Otavio será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 11
Ao todo: 11
