Ir para o conteúdo principal
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Perguntas Visualizar todos
Airport Extreme card Identification
imac 17 inch 2.0 GHtz Core 2 Duo
How do I check to see that the Wireless card is the same as the one that came with the computer when I bought it in 2006 without apples help? I don’t think they will help me on this cause you’re not supposed to take it all apart?
Can i use the FCC ID some how?
or the IC identifaction
Is there any number that could match with my computers ID???
Esta é uma boa pergunta?
Pontuação -1
2 comentários
Apple iMac "Core 2 Duo" 1.83 17-Inch (IG) Specs
Identifiers: Late 2006 CD - MA710LL - iMac5,2 - A1195 - 2124
por
Thanks I solved it.. The Box had the AP number on it. They matched
por
Adicionar um comentário
2 respostas
Solução escolhida
http://www.welovemacs.com/apimg5117mpa.h...
Apple part#661-3614
Esta resposta foi útil?
Pontuação 2
Apple part # is not unique to an individual computer however I believe that AP ID is. That is why I will use that. Thanks for try
Pontuação 0
Adicionar a sua resposta
mirolovich john será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 392
