Won't Turn on?
I have a controller that won't turn on or charge. I put a new battery in it that I know works so I didn't have to buy a new one and it still doesn't work what do I do?
Esta é uma boa pergunta?
Hi!
Was the new battery you put in, already holding a charge?
If so, it's most likely related to the motherboard...
You could replace the USB/LED board together with the cable to see if that is it, but most likely it is the motherboard.
Guide: Substituição do conjunto de carregamento do DualShock 4 (CUH-ZCT1U)
Otherwise I would check the motherboard and check it for shorts. Otherwise a motherboard replacement may be required.
Sorry!
Esta resposta foi útil?
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 14
Ao todo: 49
