Ir para o conteúdo principal
Model A1046 or A1095 / 1280x854 screen resolution
118 Perguntas Visualizar todos
Diagnose DVD RW Drive
Hi, when i put a disc in to the drive, i hear a sliding scratchy noise, and then disc comes back out. To me it sounds like the dvd-drive is dead and needs replacing. what else might it be, causing the drive not to work?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Look inside the drive with a very bright flashlight and
maybe a magnifier. If you're lucky you can retreive
the sticky note that was left stuck on a CD.
Inspect the ejected CD for scratch marks. Is the foreign
object that is stuck in the drive actually scratching the CD?
This can be a good indicator of whether or not the object
is just a piece of paper or something more serious.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Maurice será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 413
