Ir para o conteúdo principal
Guias de reparo, informações de desmontagem e resolução de problemas para a primeira geração do controle Sony PlayStation 5 DualSense, sucessor da série DualShock. Identificado pelo número de modelo CFI-ZCT1W e placa-mãe modelo BDM-010.
Controller LED blinking blue but won't work properly
Hi, first time soldering. I just replaced my potentiometer sticks with Gulikit TMR sticks. After I reassembled it, it started blinking without me turning it on.
The buttons don't work and my pc won't detect it wired. Even if I connect it wired, it doesn't charge, LED doesn't turn orange. Pressing or holding the power button doesn't do anything, it just keeps blinking blue like in the video above.
Here's some pictures inside, did I mess up somewhere? Any help is appreciated.
Thanks
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Most likely that something on the motherboard is damaged during repair, yes.
I also can see that one white connector damaged on the right side.
Also some trace damage near the pads on the left top side.
Please check if all the ribbon cables are connected as they should be. Also check the board for shorts.
Can you let us know how that goes?
Thanks!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
LeeBringIt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 107
