Ir para o conteúdo principal
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Perguntas Visualizar todos
What is the fastest Intel processor that this model will accept?
I want to upgrade my mac Mini A1176 intel core solo 1.5ghz,
with 1gb of ram and a 100gb hard drive.
I would like to max this computer out. I am wondering what the best/fastest processor is, that I can install in it.
Also the max ram which I know is 2gb, but since it already has 1gb, should I purchase (1) 1gb stick or (1) 2gb stick and does it accept DDR3 ram or only DDR2?
I believe I can upgrade to a 1TB hard drive, is this true and will any 2.5" drive work?
Also will the SUperdrive from a 14" 1.42ghz Ibook replace the Combodrive which is already installed?
Thank You So Much.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
2.166 reported as upgrade to this machine.
Intel-based iMac (mini) models released prior to the "Early 2009" series use 667 MHz PC2-5300 DDR2 SO-DIMMs and officially support a maximum of 2 GB of RAM, although third-parties have discovered that the "Core 2 Duo" powered models actually can support 4 GB of memory with dual 2 GB memory modules.
If this answer was helpful please remember to mark it accepted.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Riley McBride será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 727
