L3 doesn't work
L3 doesn't pressing don't work
Esta é uma boa pergunta?
Does the analog stick still make the click when you press it?
If it does, cleaning the joystick with contact cleaner may fix it.
If not the button is likely busted and the joystick module will need to be replaced. This does require a good amount of soldering skills and tools, but is doable at home with some patience!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 81
