Ir para o conteúdo principal
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Applications crashing upon launch. Unable to open
Hi there,
Due to frequent apps crashing, I cleaned out my system, zeroed the data, reformatted my HD and reinstalled 10.6.0. I find that the problem still persists. For example, Bento crashed upon trying to open it with the following report:
Quote
Process: Bento [432]
Path: /Applications/Bento.app/Contents/MacOS/Bento
Identifier: com.filemaker.bento
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: launchd [161]
Date/Time: 2010-02-25 20:40:44.018 +0700
OS Version: Mac OS X 10.6 (10A432)
Report Version: 6
Interval Since Last Report: 3135 sec
Crashes Since Last Report: 1
Per-App Crashes Since Last Report: 1
Anonymous UUID: 9BD78C7F-C6F6-4697-B1FC-47F2E117EBF3
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
Referenced from: /Applications/Bento.app/Contents/MacOS/../Frameworks/GNDataManager.framework/Versions/A/GNDataManager
Reason: image not found
Model: Macmini1,1, BootROM MM11.0055.B08, 2 processors, Intel Core Duo, 1.83 GHz, 2 GB, SMC 1.3f4
Graphics: Intel GMA 950, GMA 950, Built-In, spdisplays_integrated_vram
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), Atheros 5424: 2.0.19.4
Bluetooth: Version 2.2.0f18, 2 service, 1 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: AirPort, AirPort, en1
Serial ATA Device: WDC WD3200BEKT-00F3T0, 298.09 GB
Parallel ATA Device: MATSHITADVD-R UJ-85J
USB Device: Hub, 0x0424 (SMSC), 0x2507, 0xfd300000
USB Device: LaCie Mini Hub USB, 0x059f (LaCie), 0x06b1, 0xfd310000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8205, 0x7d100000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8240, 0x7d200000
USB Device: Apple Optical USB Mouse, 0x05ac (Apple Inc.), 0x0304, 0x5d100000
Unquote
Can anyone tell me the cause of the problem and offer a solution?
Many thanks
Roger
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
First thing I'd do is go to Apple and download/install the 10.6.2 combo update and see if that clears the problem. Ralph
http://support.apple.com/kb/DL959
Esta resposta foi útil?
Pontuação 2
1 comentário:
Also check if all your applications are 10.6 compatibles and search for updates.
por
Adicionar a sua resposta
rogera será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 1,518
