Ir para o conteúdo principal
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
67 Perguntas Visualizar todos
Squeeling noise coming from engine part of mower.
My mower started making this squeeling noise yesterday. It does this even when the blades are disengaged. I just replaced the blades & two idler pulleys. Any suggestions? It has a 50" deck.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Start with the basics - does it have oil in the engine?
Next step would be to try and narrow down where the noise is coming from. Is is coming from the starter? (assuming you have electric start) Is it coming from inside the engine? Is it coming from something binding against the output pulley?
BILL
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
gmmontgomery será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 748
