Ir para o conteúdo principal
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
Can I use my old iMac as an external display?
Hi there,
I have an old 24" "broken down" imac, and i would use is it as an external display for my new 21,5" i5 imac. Is it possible with or without modding the imac to use it as an external display?
i know that it isnt possible to use the origional displayport.
any help is welcome
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
As far as hardware goes, no. The LCD in the iMac gets its signal via the display data cable from the logic board. You can, however, use it as a display using software.
Since the connection depends on your wireless network, display performance may vary greatly.
Esta resposta foi útil?
Pontuação 2
2 comentários:
You can also use a wired connection (Ethernet) Vs wireless (WiFi) as well. In any case your iMac needs to be working to make it a slave system to your other system (Master). ThunderBolt connections between systems could offer a better solution in the future if someone were to write the needed software. But again you have to have a working system.
por
Many thanks for the info so far.
ScreenRecycler is a nice solution but it is really slow, even over an ethernet connection. Other VNC's are even slower.
I just can't imagine the fact that it isn't possible to share video and also hardware info. (master/slave)setup.
por
Adicionar a sua resposta
koen kofflard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 2,528
