Vacuum doesn't start
the lights blink with a whistle sound
Esta é uma boa pergunta?
If your INSE S6X light is blinking and making a high-pitched whistle, it usually indicates an air blockage (clog) or a blocked/worn roller brush. The whistling happens because the motor is working hard to pull air through a restricted space, and the blinking lights act as a warning system.
Follow these steps to quickly identify and fix the issue:
1. Check for Clogs and Clean the Filters
A dirty HEPA filter or a blockage in the airflow pathway is the most common culprit.
2. Inspect the Motorized Floor Brush
If the blockage isn’t in the bin or tube, it’s likely in the floor head.
3. Isolate the Motor
To confirm if the issue is in the attachments or the main motor:
4. Check for Motor/Seals Damage
If the handheld motor still whistles and flashes on its own with no attachments connected, dust may have entered the motorhead, or a seal may be damaged.
For a visual guide on checking your vacuum's attachments and motor connection points to resolve abnormal noises:
My INSE V120 Stick Vacuum Has Failed!
If the issue continues even after a deep clean, your battery may be struggling or the motor may require replacement.
Esta resposta foi útil?
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 43
Ao todo: 185
