Ir para o conteúdo principal
Um disco rígido externo da LaCie, também disponível com uma capacidade de armazenamento de 320 GB.
Hard drive not recognised
Hi,
I’ve got a “vintage” LaCie Petit hard drive that I had not plugged in in a while (understand a good 10 years). As I wanted to use it, I found out my latest laptop would not recognise it. I assume this is because an old driver on my hard drive. Any idea how to proceed to be able to reuse it, please?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
When a LaCie Petit N2870 ABY25 is not recognized, it is usually caused by an outdated file system format, faulty USB ports, insufficient power, or a failed internal bridge board.
Because this is a older "vintage" mechanical drive model, follow these diagnostic steps to isolate and fix the problem.
1. Check Low-Level Visibility
Before troubleshooting software, verify if your computer's operating system registers the physical hardware connection.
  • On Windows: Right-click the Start menu, open Disk Management, and check the bottom pane. If the drive shows up here but lacks a drive letter, right-click it and select Change Drive Letter and Paths to assign one
  • On Mac: Open Disk Utility (via Applications > Utilities). Look for the LaCie drive in the left-hand sidebar under "External". If it appears greyed out, select it and click the Mount button at the top.
2. Isolate Connection and Power
Older mechanical drives are highly sensitive to power delivery and interface changes.
  • Eliminate Adapters: Plug the drive directly into your computer's built-in USB ports. Avoid using unpowered USB hubs or extensions.
  • Swap the Cable: A degraded USB data cable can supply enough electricity to light up a drive without actually transmitting data. Swap the cable with a known working replacement.
  • Check the Power Supply: If the drive makes a rhythmic clicking noise or fails to spin entirely, it is not getting sufficient power. Ensure you are using the specific 12V 2A external AC wall adapter rather than relying solely on USB bus power.
3. File System Compatibility
If you recently switched computers or haven't used the drive in a long time, the format might block access.
  • NTFS Format on Mac: A drive formatted for Windows (NTFS) will sometimes fail to mount or act erratic on newer macOS versions.
  • Reformatting: If the data on the drive is not important or already backed up, you can use Disk Management (Windows) or Disk Utility (Mac) to format it to a universal layout like ExFAT. Warning: Formatting will permanently delete all files on the drive.
Esta resposta foi útil?
Pontuação 0
Hello,
If your LaCie Petit drive has been unused for around 10 years, the issue is unlikely to be a missing driver on the drive itself. More commonly, one of the following may be happening:
• The USB cable or USB interface may have deteriorated over time.
• The drive may be formatted with an older file system.
• The drive may not be receiving sufficient power from the USB port.
it's mostly age related, but should be easy to fix. not sur eif you have mac or windows but what you want really do is dowble check if the drive is getting detected.
what you can do is-
Connect the drive using a different USB cable (if the cable is removable).
Try different USB ports and, if possible, another computer.
Check whether the drive appears in Disk Management (Windows) or Disk Utility (Mac).
Listen for any unusual clicking, beeping, or repeated spin-up/spin-down sounds.
If you heare clickinhg noises or notice any symptoms that may indiacte that it is ahrdware issue, then take it too a professional service.
If the issue is logical, there are data recovery services, but you could also use any data recovery software if you are looking for a more convenient alternative.
Pontuação 0
Adicionar a sua resposta
Delphine MARSAN será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 62
Ao todo: 254
