Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
Looking for a ps4 midframe part
I'm looking for a ps4 midframe part that looks like this
https://ibb.co/ksFFtFWj
Here's a website called fasttech where the part is in stock
https://fasttechstore.com/playstation-4-...
My question is are the parts exactly the same? I do have a CUH-1115A ps4 and the fasttech website seems to have the correct part in stock. From the pictures on fasttech.com, I really can't tell.
On fasttech.com, the back of the part, where the lan and hdmi plug in, it doesn't look slanted in the pictures.
I'm 99.9% sure that this is the correct part. The only reason I'd like to replace the part is because heat from the hardware has caused the plastic to break apart.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Justin,
Yes, as long as the model is exact the same, it should fit.
In your case, this is the case, so it should fit without any issues.
It's possible that they used a different model frame as reference photo.
You can always contact them to double check. If it does not fit, then return it and ask for a refund.
But again, most likely this one will fit without any issues.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Justin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 24
Ao todo: 42
