Ir para o conteúdo principal
Controle PS4 modelo CUH-ZCT1. Lançado em novembro de 2013 pela Sony Computer Entertainment, este controlador de seis eixos com bateria de íon de lítio de 3,7 V é simples de reparar. (NOTA: O guia de desmontagem NÃO é para este modelo)
Am I using this program correctly?
Hi so I finally got the analog sticks on my controller these are the Gulikit TMR Joysticks and I dont know whats going out with the right analog stick it clicks, but doesn't register and it looks like it drifts even though they supposed to be new. I tried in BF6 and I don't notice it since I have my dead zone set to 0. Can too much or little solder cause that malfunction?
Esta é uma boa pergunta?
Pontuação 0
5 comentários
Hi!
Can you set us pictures regarding the solder work?
Adicionar imagens a uma pergunta já existente
Thanks!
por
Hi, I uploaded the photos it starts from the top going clockwise
por
Hi!
Thanks for the pictures! The pads do look damaged in the 2nd and 3rd photos. Can you remove the solder there and sent a photo again? Is that possible? Thanks!
por
I will do it as soon as I can
por
Hi, I uploaded the removed solder from the 2nd photo I did noticed the exposed copper
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
It does look like that the pads are damaged, causing this issue.
I’m afraid you need to repair the pads first.
Here is some explanation: https://youtu.be/dtZl7cLYc40?is=0ieMGMQp...
Please let me know how that goes!
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you I'll just a new MB and analog sticks it always something with this and its getting tiresome
por
I understand yes, I would swap it out for a new motherboard as well. Please let us know how that goes! Thanks!
por
Adicionar a sua resposta
Christopher D será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 60
Ao todo: 60
