Ir para o conteúdo principal
O headset de realidade mista Meta Quest 3S foi lançado em 15 de outubro de 2024 e é um irmão mais novo e compacto do Meta Quest 3.
Headset's tracking completely stopped working
I was playing VRChat on this headset and the tracking on it completely stops working where the cameras are off and the microphone only works if I hold the power button (after 5 seconds of holding it would shut it down) as well as the controllers not responding to anything beside the quest menu button so I had to use the head direction movements and volume buttons to navigate around the menus. I went to the Headset Tracking option and the switch is stuck on as it won't let me toggle it at all.I'vr also used ADB to clear the data of all the oculus system apps and restart it to safe mode but it didn't fix the problem. Is there something wrong with the hardware or does it need to be factory reset?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
I would try to factory reset it but if that doesn't work try to send it back if you have warrenty
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kai Bannon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 37
Últimos 30 dias: 96
Ao todo: 643
