Memory upgrade: 1.5V instead of 1.35V possible?
Is it possible to use 1.5V DDR3 instead of 1.35?
There are lots of cool DDR3 1600MHZ CL9 SODIMM's available at my location but not any DDR3L :(
Esta é uma boa pergunta?
Here's what's supposed to go in it:
Technology: DDR3L SO-DIMM
Density: 8GB (8192MB)
RoHS: Yes
Pin Count: 204-pin
Op. Temp.: 0C to +85C
Data Rate: DDR3L-1600
Speed: PC3-12800
CL: 9
Cycle Time: 1.875ns
Voltage: 1.35V
ECC: Non ECC
Module Ranks: Dual Rank
Register: Non Parity
Low Noise 8-Layer PCB
Esta resposta foi útil?
I am using 1.5V RAM in the MBP 2012 13''. No problems.
Corsair Venegance CL9 PC3-12800 2x4GB
strange -- my 2012 13" MB Pro came with 1.5V memory from Apple..... I upgraded it with 8gb of the same type of memory (1.5V). No problems.
Hi, like senthor I ordered also the Corsair Vengeance Kit with the CL9 Timing.
Is there now any new information about the usage of 1,5V RAM?
All the 1,35V RAM modules I found have a CL11 Timing...
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 9,668
