Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
Tools Needed to upgrade HD to SSD
I took the back off and was surprised to find the mounting screws or torx?? I didn't have the right tool so I had to close it back up. The Type 00 screwdriver took the back off but did't know what torx # to use to use the brackets.
Thanks.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Here are the tools needed to do the teardown on this machine:
Tools
Here's the iFixit teardown: MacBook Pro 15" Unibody Mid 2012 Teardown
Links are given on the teardown on where to buy rhese tools.
Imagem de A tougher take on a favorite multitool. Safely poke and pry with this tough, firm, and antistatic tool for electronic repair. 5” carbon fiber tool essential for smartphone or tablet disassembly.
Produto
Spudger
$3.99
Imagem de Use to take apart and repair your computer. Swivel top handle with precision tip driver.
Produto
T6 Torx Screwdriver
$9.99
Imagem de Precision fixed blade Standard Phillips screwdriver used to take apart laptops. Engineered by iFixit.
Produto
Phillips #0 Screwdriver
$5.49
Imagem de Precision fixed blade screwdriver engineered by iFixit.
Produto
Phillips #00 Screwdriver
$5.49
Imagem de Three pointed screwdriver. Fits many tamper-proof three pointed fastener heads, including those found on MacBook Pro batteries. Similar to, and acceptable replacement for, Apple Tool 922-8991. Swivel top handle with precision tip driver.
Produto
Tri-point Y1 Screwdriver
$5.49
Imagem de Organize and magnetically secure your screws and small parts on a dry erase surface. Make notes with included pen.
Produto
Magnetic Project Mat
$19.95
Esta resposta foi útil?
Pontuação 2
Its the Torx T6 (6.0mm), i did the replace myself last saturday.
Pontuação 0
1 comentário:
Type 00 for the screwdriver for back plate?
por
Adicionar a sua resposta
BostonBri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 42,559
